AiPi-LoRaBoard
AiPi-LoRaBoard
Introduction Video
1. Overview
AiPi-LoRaBoard is an expansion board designed for the AiPi-UNO-ET485 development board, equipped with the Ra-08 module and a 1.9-inch MIPI-DBI capacitive touchscreen.
Ra-08 operates in the frequency range of 410MHz to 525MHz, compatible with connections to LoRa modules such as Ra-01/SC, Ra-02, etc. The antenna default uses a 433MHz small pepper antenna (communication distance not tested). If Ra-08H is replaced, the frequency range of 803MHz to 930MHz can be utilized.
The 1.9-inch screen features an MIPI-DBI interface, 170*320 pixels, and supports capacitive touch.
2. Development Resources
2.1 User Manual
Instructions for using AiPi-LoRaBoard with AiPi-UNO-ET485:Click to download
2.2 PCBA Data
- AiPi-LoRaBoard Schematic:Click to download
- AiPi-LoRaBoard JLCPCB Open Source Square Address:AiPi-UNO-ET485 LoRa扩展板—AiPi-LoRaBoard
2.3 Factory Firmware
- Ra-08 Firmware, Master-Slave Integrated:Click to download
- AiPi-UNO-ET485 Firmware:Click to download
