Ra-01SCH-P
- Key Features
Ra-01SCH-P
  • The Ra-01SCH-P is a LoRa series module designed and developed by Shenzhen Ai-Thinker Co., Ltd. Designed for ultra-long-range spread spectrum communication, its RF chip LLCC68+ utilizes the LoRa™ remote modem, offering strong anti-interference capabilities and minimizing current consumption.
- Technical Highlights
  • Supports FSK, GFSK, and LoRa® modulation.
  • Covers the frequency band 803MHz–930MHz.
  • Adjustable maximum transmit power:
    • ① Default configuration: Internal PA powered by 3.3V, achieving up to +29dBm TxPower at 750mA current.
    • ② Optional configuration: Internal PA powered by 5V, achieving up to +31dBm TxPower at 1A current.
  • Ultra-high sensitivity: As low as -137dBm@SF10125KHz.
  • Compact size: 17×16×3.2(±0.2)mm, dual-row stamp-hole SMD package.
  • Supports spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11.
  • Low power consumption in receive mode: Minimum 16mA receive current.
  • SPI interface with half-duplex communication, CRC, and 256-byte packet engine.
  • Flexible antenna installation: Compatible with half-hole pads, through-hole pads, and IPEX connectors.
Ra-01SCH-PViewDownload
3. Compliance & Testing
- Power Consumption Test Reports
- Hardware Reliability Test Reports
