Ra-01SC-P
- Key Features
Ra-01SC-P
- The Ra-01SC-P is a LoRa series module designed and developed by Shenzhen Ai-Thinker Co., Ltd. Engineered for ultra-long-range spread spectrum communication, its RF chip LLCC68+ utilizes the LoRa™ remote modem, delivering robust anti-interference capabilities and minimizing current consumption.
- Technical Highlights
Supports FSK, GFSK, and LoRa® modulation.
Covers the frequency band 410MHz–525MHz.
Maximum transmit power of +29dBm at 700mA operating current.
Ultra-high sensitivity: As low as -137dBm@SF10125KHz.
Compact size: 17×16×3.2(±0.2)mm, dual-row stamp-hole SMD package.
Supports spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11.
Low power consumption in receive mode: Minimum 11mA receive current.
SPI interface with half-duplex communication, CRC, and 256-byte packet engine.
Flexible antenna installation: Compatible with half-hole pads, through-hole pads, and IPEX connectors.
Module | Datasheets | PCB Footprints |
Ra-01SC-P | View | Download |
3. Certification Related
Moudles | Certificate | Link |
Ra-01SC-P | CE (RED) | View |
Ra-01SC-P | FCC | View |
